46RE replacing 8 pin connector/harness
Old Feb 21, 2023 | 09:52 AM
baarf's Avatar
baarf
I'm going to take pictures of what I have. Might help. Can't hurt.
Old Feb 21, 2023 | 09:54 AM
baarf's Avatar
baarf
will it damage anything to drive it with the connector unplugged? I can manually shift 1-2-3
Might have to go to a shop and see if they have a way to figure this out.
Old Feb 21, 2023 | 09:55 AM
You will have to shift manually, but, aside from that, won't hurt anything.
Old Feb 21, 2023 | 09:56 AM
In addition, if you have the service manual, it will show the pinout for the connector, and what color wires are supposed to go to what pin. That may help you sort things out.
Old Feb 21, 2023 | 10:15 AM
baarf's Avatar
baarf
I have the service manual in pdf. do you know where to find it? looking now
Old Feb 21, 2023 | 04:47 PM
What year is your truck?
Old Feb 21, 2023 | 05:48 PM
baarf's Avatar
baarf
sorry it took so long, life happened
1997 Ram 1500 5.9 V8 4x4 gas 46RE transmission
Old Feb 21, 2023 | 05:49 PM
baarf's Avatar
baarf
Old Feb 21, 2023 | 05:50 PM
baarf's Avatar
baarf
I think that is correct. The problem is there are 2-4 wires that are pretty much the same color.
I am going to take pictures Thursday if I don't make any progress and post them here
Old Feb 22, 2023 | 03:33 PM
Red one is going to be the fat wire. 5 volt supply will be easy to identify as well... just test for voltage. (ignition on, engine doesn't have to be running.) as for the rest...... yeah.... maybe some brake cleaner, and bit of rubbing will bring up the original color?
