No spark
Old Feb 25, 2023 | 09:58 AM
  #21
rfriedersdorf's Avatar
rfriedersdorf
Fuel pump runs when you first turn on ignition. Also there is a clicking noise under hood when ignition is on. Will get a meter and make some more checks
Thanks,
Old Feb 26, 2023 | 10:28 AM
  #22
Moparite's Avatar
Moparite
Find out what is clicking, If it's the asd relay you may have found the problem.
Old Feb 27, 2023 | 11:15 PM
  #23
rfriedersdorf
Ok will check it tomorrow when I get home from work and let you know.
Thanks
Old Mar 2, 2023 | 08:35 PM
  #24
rfriedersdorf
Tried 3 brand new relays, but still no spark. even tried jumping from pin 30 to 87 with relay out and still no spark. When I pull relay out completly or jump accross, all gages work. The fuel gage reads almost full and that is where it should be. With at relay in, fuel gage reads empty, doesn't move at all. At a real loss now. Just wondering, is there any way to check the ECM (computer)? Maybe it went out and the one I got from junk yard is also bad.
thanks
