Power windos issue, 2001 dodge ram 2500
Old Feb 24, 2023 | 06:56 PM
jesus gerardo's Avatar
jesus gerardo
Default Power windos issue, 2001 dodge ram 2500
I recently change the power window assembly and motor of the driver side door, but i have a problem now when i fully lower the window i gets stuck with the edge trim piece of plastic and noticed that the window kinda goes off track
any help?
Old Feb 24, 2023 | 07:16 PM
Pull the door panel, make sure all the window tracks are properly secured. Also, I think the bottom rail on the window is just glued in place to the window,,,, make sure that hasn't separated.
Old Feb 24, 2023 | 07:24 PM
jesus gerardo
i already check that, everything looks ok, but i dont know what could it be because before changing the assembly everything was oki didnt have any problems, but thanks for the help will check that again, maybe i miss something
Old Feb 24, 2023 | 07:26 PM
Compare the window regulators. There should be a 'down stop' on them.... do they look the same?
