Cluster Problems
Old Mar 14, 2023 | 01:36 PM
Jaw91097's Avatar
Jaw91097
Default Cluster Problems
Alright so my 98 1500 with a 360 automatic stopped reading the mph, I'm assuming thats just the sensor in the rear end? The same time that that happened, my mileage stopped counting, its stuck right at 176351 for the last three weeks. My other issue is that my check gauges light comes on, oil pressure plummets to zero, then back up, and the light goes away. I'm assuming that would just be an oil pressure sensor or does that seem more like a problem with the gauge itself? TIA - Jake
Old Mar 14, 2023 | 05:33 PM
Sounds like the rear wheel speed sensor is bad, as that will affect both the speedo, and the odo.... and the oil pressure sensor is goin' south as well. Fun to change.... You can see it, or, you can touch it, but, ya can't do both at the same time.
Old Mar 16, 2023 | 10:56 AM
Jaw91097's Avatar
Jaw91097
Well I got both done last night, speedo and odo work fine now without a brake light on. Oil pressure is showing but it seems like whenever I turn left, right, or brake a little too hard coming to a stop it seems to plummet to zero with a "Check Gauges" light coming on, then it'll go away and pressure will go right back up. So its doing the same thing even with a new sensor. Any ideas?
Side note, while doing the oil sensor, I found a ground strap just chilling behind the intake, not connected to anything, so I'll work on that this weekend. TIA
Old Mar 16, 2023 | 10:59 AM
How is your oil level??
Old Mar 17, 2023 | 01:47 PM
Jaw91097's Avatar
Jaw91097
I suspect it was low, I did an oil/filter change, and it hasn't come back on. I think the plenum is drinking more than I realized. I feel stupid for that one haha, thank you!
Old Mar 17, 2023 | 08:31 PM
Yeah, that's what mine did when oil got low.... for the same reason.
