2500 Lowering
Old Apr 21, 2023 | 12:16 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
2nd gen dodge 2500 4x4 lowering in Google search. Many articles to read from there and also You tube has some videos.
Old Apr 21, 2023 | 04:05 PM
KillerLemming's Avatar
KillerLemming
I'm looking for a 2wd. Its a bit different than 4wd
Old Apr 21, 2023 | 07:32 PM
Tudor's Avatar
Tudor
Hello to all forum participants, I'm new to this site, I want to know more about this car, now I was on vacation in Canada And I really liked this car, I want to know more about it.
Old Apr 21, 2023 | 08:10 PM
What car?
Old Apr 22, 2023 | 10:03 AM
Keith_L's Avatar
Keith_L
What car?
Dude, total bot. Delete account
Old Apr 22, 2023 | 03:16 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
The same applies to a 2wd and a lot more info on this out there. Do a spring under and dropped front spindles, get lowering springs, take out leaves from the rear springs, go to the JY and find a set of worn springs that are flat, cut the front springs (not recommended by me), cut and channel the body, go with smaller tires, take the blocks out in the rear, find a truck that is already lowered. No matter how you drop it it's going to cost time, materials, tools
Old Apr 22, 2023 | 09:45 PM
Keith_L's Avatar
Keith_L
He's just looking to lower the rear a little while maintaining payload capacity
I'd do longer shackles and raise the front spring hangers. The latter may require cutting rivets and drilling a few holes, but overall lowering a leaf spring solid axle is about as simple as it gets.
It's also possible that longer shackles alone will get you there with no driveline vibes. Generally the rough rule of thumb is 50% of change in the shackle length, so shackles that are 3" longer oughtta drop you ~1.5"
Admittedly, I don't know how much space is available until your rear spring eye runs into the bed.
Old Apr 23, 2023 | 09:09 AM
HeikIlm's Avatar
HeikIlm
There is 4" from top of the spring eye to the bed floor.
