5.9 rebuild question
Old May 21, 2023 | 05:33 PM
Alexdabest's Avatar
Alexdabest
Default 5.9 rebuild question
I've been overhauling my 5.9 magnum. Replacing heads, cam, bearings all around, lifters, timing assembly, rod, pistons, rockers, etc.
I bought Enginequest heads, and a very mild comp cam.
I also purchased valve springs recommended by comp to go with the cam. Turns out the springs don't fit the heads, stock or EQ.
My underlying question is, do I even need to replace the springs with the new heads (that came with new valve springs) given that the cam is only a very mild upgrade? If so, does anyone have any recommendations on good valve springs, that aren't expensive? I was trying to do a budget build, obviously not anymore, but I'm not looking for insane HP, just something that will function properly with both the cam and heads. Again, these springs were purchased on summit racing, and were RECOMMENDED to be purchased together through summit racing.
Comp cam: CCA-20-745-9
Comp springs: CCA-901-16
Thanks in advance!
Old May 21, 2023 | 08:11 PM
What do you mean by 'don't fit'? If the spring pockets aren't large enough, you can have them machined.... Have you talked to comp cams, and see what they suggest?
Old May 21, 2023 | 08:40 PM
Alexdabest's Avatar
Alexdabest
Yeah that's the issue I've had. And I would machine them, but all machine shops near me are booked out 3 weeks-6 months, so id rather not do that if I don't have to. Unless there's some way I can do it myself. The amount of machining that would be necessary is minimal
And no, I havent personally talked to comp cams about it. I've just done research online.
Old May 21, 2023 | 11:35 PM
AtomicDog's Avatar
AtomicDog
There is a tool that you can purchase to machine the spring seats on the head. This is the same thing that the machine shop would have to do. You can do a Google search for 'valve spring seat cutter' to find out more information.
Old May 21, 2023 | 11:40 PM
Alexdabest's Avatar
Alexdabest
Awesome, I'll check it out. Thanks!
