1998 dodge ram 2500 5.9L V8 4x4
Old May 25, 2023 | 09:52 PM
Kgauer21's Avatar
Kgauer21
Default 1998 dodge ram 2500 5.9L V8 4x4
Can someone tell me what this is? It turned on and made a buzzing noise when I turned my truck on and now it won’t turn off even after I turned the truck off. I had to unhook the battery
Old May 25, 2023 | 09:54 PM
ABS module. Shouldn't be powered when the truck isn't running.... (ignition on, at any rate.) and it should only buzz for a few short seconds, and stop.
Old May 25, 2023 | 10:01 PM
Kgauer21's Avatar
Kgauer21
so I’m guessing my ABS is faulty now and I have to replace it?
Old May 25, 2023 | 10:52 PM
ol' grouch's Avatar
ol' grouch
Not necessarily. There may be something activating it that is stuck. Fix the cause, not the symptom.
Old May 25, 2023 | 10:54 PM
DerTruck's Avatar
DerTruck
Possibly but try to make sure that's the problem. IIRC you can't get these modules anymore and it's either the junkyard or a rebuild service. Both of which are hit and miss.
Fuse 11 (40A) in the PDC is permanent power to the ABS module. There is also a switched power connection but for now let's assume that it turns on/off as designed. So pull fuse 11 and see if the noise goes away. Then, disconnect the connectors and look for corrosion or heat marks etc.. A couple of years ago I had a nagging circuit error that was remedied with some contact cleaner and exercising the ABS on a dirt road.
