Vehicle stalls
Old Jul 6, 2023 | 08:39 PM
Onecoolram's Avatar
Onecoolram
Default Vehicle stalls
I have a 98 dodge ram 1500 sport with the 5.9 engine. I can drive about 20 miles stop and turn the engine off. When I start it back it will fire up then die, 2nd attempt it will fire right up. When I put it start to back up and apply the brake it dies. I give it gas get it going and it runs fine. I have installed a new tps and egr valve. I have visibly checked for vaccum leak but have found none. The battery that is in the vehicle isn't the recommended size as it is a little smaller. Could this be my problem?
Old Jul 7, 2023 | 10:36 AM
Moved to the correct section.
Old Jul 7, 2023 | 01:09 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
Curious, a 1998 motor shouldn't have an EGR valve on it. Are you sure about that?
Might want to check the fuel pressure to see what it reads. There should be a port on the fuel rail to allow for the fuel pressure check.
Old Jul 7, 2023 | 01:47 PM
Onecoolram's Avatar
Onecoolram
Sorry i meant pcv valve
Old Jul 7, 2023 | 02:00 PM
AtomicDog's Avatar
AtomicDog
Thanks for clarifying. As for the battery, as long as it has enough cranking amps and general amp capacity, you should be fine.
Old Jul 7, 2023 | 02:06 PM
Cleaning the throttle body wouldn't hurt either.
