Speedo signals
Old Jul 9, 2023 | 07:18 PM
Speed sensor is gear driven tone generator. Adjusting your speedo is as simple as changing the driven gear.
Old Jul 9, 2023 | 07:40 PM
JackJack135's Avatar
JackJack135
I thought that was true of the Dana 70 in the rear. I’m pretty sure the 47re tailhousing uses a magnetic coil and a raised lip on the output shaft to measure the speed.
Old Jul 9, 2023 | 08:10 PM
So far as I know, the 47VSS works exactly the same as the 46.... Now, if your drivetrain is 98 or newer, then its the speed sensor on rear diff that's used for speedometer.
