2nd gen engine and tranny swap help
Old Aug 4, 2023 | 07:10 PM
Raminator 6996's Avatar
Raminator 6996
Originally Posted by wopl400
could the op do 1 of the fallowing remove engine trans cab harness and under hood harness with pcm and put them in his 97 people go from obd1 to obd2 so I do not see why this would not work or could he just swap his engine and trans and send his 97 pcm out to be flashed for the bigger engine and manual trans and just shift his auto manually?
Could I keep the 1997 318 and just switch the pcm so it's obd1 and possibly wiring harness so I have the 3 pin connector for the 47rh
Old Aug 4, 2023 | 07:37 PM
If you are going to go to all the trouble of converting to OBDI, why not use the 360??? That is what the PCM is expecting in any event.....
Do you have inspections where you live though? As converting back to OBDI will most certainly fail on a 1997...... If you don't have inspections, then it isn't a concern.
Old Aug 5, 2023 | 10:15 AM
Raminator 6996
I'm in northem Michigan so no vehicle inspecting l. The 360 is having oil pressure issues and I think the previous owner overfilled the oil by about 3times the amount as a bandaid or by accident. The 318 I have has always been very reliable
Old Aug 5, 2023 | 11:39 AM
Rebuild your original trans then. Probably end up being cheaper and easier.
Old Aug 5, 2023 | 08:19 PM
Raminator 6996
would I be able to use some of the old parts from the rh like the valve body And stuff, I have a friend with a Cummins that has a little experience in taking two 2nd gen dodges trannys and making things work who might be able to help me rebuild it . BTW I got two 46 re the original that one day only went in reverse and the other a free used one that just quit working a week later ( possibly torque converter) with all this tranny parts I might be able to get something going. I just got laid off on my comstruction job so I really need this to come together to get to my new job so I got limited amount of founds Mayne 3 to 400
Old Aug 5, 2023 | 10:30 PM
Too many differences between RE and RH for valve bodies to interchange. rotating parts will though.
