1994 Fuel Tank Configuration - Pump or no Pump?
Old Jul 28, 2023 | 02:24 PM
diesel85's Avatar
diesel85
Default 1994 Fuel Tank Configuration - Pump or no Pump?
Hi Guys,
New to this forum and am working on a 1994 DIESEL 2nd gen project. Here is the issue:
The fuel tank was removed from the truck when I acquired it and I am now putting it back together (see picture). I've been told that I am missing a fuel sending unit AND a fuel pump? So, can someone tell me what the truth is?
IS THERE A FUEL PUMP AND SENDING UNIT IN THE TANK OR JUST A SENDINIG UNIT?
Bonus: Would be GREAT if you can post a picture of exactly what I need!!
The fuel tank
Info on fuel tank
Tank opening and hoses
Old Jul 28, 2023 | 03:11 PM
aleekat's Avatar
aleekat
Fuel pump & housing assembly includes sending unit. Go up Rockauto.com. They have pics. What engine?
Old Jul 28, 2023 | 05:45 PM
diesel85's Avatar
diesel85
12V Diesel engine
Old Jul 29, 2023 | 07:26 AM
Moparite's Avatar
Moparite
There is an orientation witch way it goes in. Since you don't know that experiment and make sure the sender arm bottoms out and has free movement. otherwise you will get a incorrect fuel reading.
Old Jul 29, 2023 | 04:01 PM
HeikIlm's Avatar
HeikIlm
No fuel pump in the tank on a 12 valve diesel. Mechanical lift pump is on the left side of the engine, under the fuel filter.
Old Jul 29, 2023 | 04:53 PM
HeikIlm's Avatar
HeikIlm
Since the fuel tank from my '95 diesel truck is so conviently removed and on my garage floor, I took couple of pictures.
No lift pump here:
This holds the unit in place, and also needed is the wide rubber seal around the sending unit:
Old Aug 3, 2023 | 08:48 PM
diesel85's Avatar
diesel85
No lift pump here:
THANKS SO MUCH for the pictures.......This definitely helps a TON!
Old Aug 8, 2023 | 10:30 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
All the tanks I messed with the fuel module had an arrow you line up to an arrow on the tank
