Manual swap
Old Aug 19, 2023 | 10:06 PM
Chayten stroop's Avatar
Chayten stroop
Default Manual swap
So I have a 98 ram 2500 and it needs head gaskets and a tranny rebuild but my heads were cracked and I found a really good deal on a 92 ram with a 360 non magnum I’m pretty sure and a 5 speed trans not sure if it’s an nv3500 or nv4500 but I know I can put that motor and tranny in my truck but will the master cylinder, slave cylinder, and everything else I need for the manual swap fit in my 98 and if not what all is needed for it to work
Old Aug 19, 2023 | 10:41 PM
Not gonna be a simple swap. All the instruments are driven via the PCM....
Should be NV4500 behind a 360. It's also likely throttle body injection, and the kegger intake (port injection) won't bolt to it.
