Stolen truck missing parts. Need help identifying
Old Oct 8, 2023 | 09:43 PM
Kayden Barrios's Avatar
Kayden Barrios
Default Stolen truck missing parts. Need help identifying
96 dodge Ram 2500 V10 4X4
Hey dodge family, I just got my truck back after it was stolen and I’ve dealt with load of issues already. I got it to start but not without it spraying a big flow of gas out of this uncapped spot on the injector line, every time it starts. My question is what do y’all’s look like on your trucks is there a cap on this or is it supposed to have a fitting inside it to keep the gas pressure there? If anything could a guy just grab a brass threaded cap and put that on there? If so does anybody know what size?
Old Oct 8, 2023 | 10:01 PM
AtomicDog's Avatar
AtomicDog
Lightbulb
That's likely the test port for the fuel injection to determine if the appropriate amount of fuel pressure is on the rail. I suspect someone removed the valve that should thread into the center of that port in addition to the threaded cap. The valve should thread into the port the same way a schrader valve threads into a tire stem.
Old Oct 15, 2023 | 11:00 AM
Jimythefan's Avatar
Jimythefan
Sorry, just saw this. Yes threaded insert then a cap to protect it. Here's mine if it helps any.
