tranmission shifting issue
Old Oct 9, 2023 | 06:52 PM
BrandonBuc'em's Avatar
BrandonBuc'em
Default tranmission shifting issue
i want to say the first time the issue im about to outline happened when a dude at a grocery store complimented me on my truck as i was leaving and i told him id get on it a little for him, i mashed the gas maybe....25-30 mph. nothing crazy but when i pulled out from the red light after it wouldnt shift from first gear, i pulled over and went from n to p, up and down all the different gears no change. soooo i just tried to limp it home, when i pulled out again it still didnt want to shift but after about 2 mins it eventually shifted to second and onward. made it home fine and no issue since. FAST FORWARD!!! last week i mashed the gas for the first time since and now my transmission barely wants to shift anymore. i have to be just barely on the gas for it to shift and it seems if i accelerate medium to hard it wont shift. i dont want to just start throwing parts at it so i was hoping the details ive given someone could guide me in what they think. thanks!!
Old Oct 9, 2023 | 11:25 PM
AtomicDog's Avatar
AtomicDog
Do you have a ODB2 code scanner? Any codes?
Old Oct 11, 2023 | 10:01 AM
BrandonBuc'em
Yes but unrelated to transmission codes. Down stream o2 sensor (no cat) and evap leak that I've had since buying the truck.
Old Oct 12, 2023 | 12:23 AM
jonwil91's Avatar
jonwil91
When is the last time your tranny fluid was changed or checked? I would first check the trans fluid, and if it is fine, then I would change the fluid and filter. Mine which is a 99' has been having a trans issue, but since i have been working pretty much every day can't really work on it. It just likes to downshift at weird times.could just be dirty fluid or a filter. But yeah, i would check your fluid/filter first before you delve into more complex stuff lol
