Parasitic Draw That Needs Multiple Fuses and Computer Unplugged
Old Oct 24, 2023 | 07:24 PM
  #21
Davidhall2011's Avatar
Davidhall2011
Originally Posted by DerTruck
That would point to some sort of electronic control module staying on until something changes that makes it go to sleep. Fuse 3 in the underhood PDC is the main power for the PCM and fuse 9 inside is the switched power. Does pulling either of these make any difference ?
I pull the number 3 fuse out with the pcm plugged in and that draw goes away but as soon as I plug in the central timing module or the flasher in I have a draw
Old Oct 24, 2023 | 07:27 PM
  #22
Davidhall2011
Try disconnecting the central timer module. A lot of stuff is not going to work but see if the current draw goes away.
Now that I figured out the first draw when I plug the central timing module or the flasher relay in it has a draw
Old Oct 25, 2023 | 06:38 AM
  #23
Moparite's Avatar
Moparite
#3 is Controller Antilock Brake (ABS) Have you tried a new flasher? May have an issue with both flasher and ctm.
