1998.5 2500 24 V can you guys recommend a rear Air Bag kit for towing/hauling?
Hi, I am looking to add an air bag kit to the rear for when we are towing or hauling in the bed. What kits have you guys used and liked? I see the Firestone kit the instruction say to remover wheel well liner but it is not clear if I can put it back after the install which I like them in.
Any compressor recommendations if I decide to do the on board compressor.
Would a portable aux type compressor work if I don't want to wire it to the truck?
Pros/Cons? Thanks
Pros/Cons? Thanks
No real clue on the fender liners, but, I suspect if you wanna put 'em back, prolly have to do some trimming on 'em.
If you don't want on-board air, its just a schrader valve to pump up the bags. Standard tire valve stem, so, any 12 volt compressor will work.
