Blend door actuator
Old Nov 28, 2023 | 10:26 PM
Patriotracing99's Avatar
Patriotracing99
Default Blend door actuator
So on this 2001 dodge ram 2500 the heater blend door coupling was cracked letting the actuator spin all the way around, I replaced the coupling. But now the control switches from cold to hot. But off mid point it doesn't matter one click or 5 or all the way. It's either all hot or all cold there is no in between. The actuator turns until blend door open or closed all the way? What do I need to do to get the in-between?
Old Nov 28, 2023 | 11:16 PM
Keith_L's Avatar
Keith_L
Did you realign the gears? Watch the video
https://heatertreater.net/dodge-ram-95-02
Old Nov 28, 2023 | 11:26 PM
Patriotracing99
No I have not done that yet.. it must be a timing thing with gears then?
Old Nov 28, 2023 | 11:29 PM
Patriotracing99
Thank you for that read. That explains everything I've been questioning about the blend door position. Ok I will align gears tomorrow. Thank you
Old Nov 29, 2023 | 10:40 AM
Keith_L's Avatar
Keith_L
Let us know if it works!!
