3in Leveling kit for 2000 1500
Old Dec 29, 2023 | 07:29 AM
oldustrr's Avatar
oldustrr
Default 3in Leveling kit for 2000 1500
I know I posted it somewhere, but is there a differential drop kit for the 1500 from 2000? I have a 3in leveling kit and everywhere I’ve looked said to either diff drop and 3in level or don’t level at all because it puts stress on the front end at that height. I bought the kit so I would like to install it and I’m not opposed to shelling out 200-300 on a kit I just can’t find any.
Old Dec 29, 2023 | 09:14 AM
The diff drop kit is for the trucks with independent front suspension. 2000 is solid axle. So, simply not a concern.
Old Dec 29, 2023 | 09:25 AM
oldustrr's Avatar
oldustrr
I do have a rwd 1500, does that change anything
Old Dec 29, 2023 | 10:10 AM
Then you don't even have a front differential. A 3" leveling kit does have the potential to push the ball joints in front to their limits though. Trust me when I tell you having one break while you are driving is no fun at all. 2" is likely safe, or, safer, at least.
Old Dec 29, 2023 | 12:00 PM
oldustrr's Avatar
oldustrr
can’t find any upper or lower control arms that would work with a 3inch leveling kit, should I just go a size down? Thanks!
edit: I have the 3inch kit, don’t want to buy another one but if it is the only way, then it’s the only way. Thanks!
Old Dec 29, 2023 | 12:17 PM
Well, ya gotta consider that the last of these trucks rolled off the assembly line better than 20 years ago.... and there wasn't a lot of aftermarket support when they were new. So, finding 'custom' parts for them today, is a lot like looking for an honest politician. You can search all ya want, but, finding one is pretty much a minor miracle.
What I would suggest is, get yourself a good floor jack. Put it under the front crossmember, and start raising the truck. See how much you can jack it UP, before the tires actually leave the ground.... if you get 4 or 5 inches, your 3" kit will likely be ok. If you only get a bit over 3", it *might* work, but, the ride quality is going to suffer horribly. If you barely get 3", or less than 3", then installing the kit is going to be asking for trouble, and a very unpleasant experience.
Old Dec 29, 2023 | 12:58 PM
oldustrr's Avatar
oldustrr
Thanks for all the help! It’s been jacked up before and it got a lot of clearance, but when I go to do all the fixes I’ll measure first. Thanks for all the help again!
Old Dec 29, 2023 | 02:57 PM
We want more pics. Especially during and after the lift.
