46RE Band adjustment.
Old Jan 4, 2024 | 03:39 PM
Upstate_Vet's Avatar
Upstate_Vet
Default 46RE Band adjustment.
I bought this truck (1999 1500, 5.9 4wd) in 2021 for a decent price because it wouldn't shift into 2nd gear. Took it to the trans shop and they said the band for 2nd was bad. They wanted to drop the tranny and do a full rebuild.
​​I couldn't afford that then . Or now. They suggested to use a slip in band and that it was cheaper and would fix the issue.
It definitely fixed the issue, and was cheaper than a rebuild ($600) so I was "happy".
Last week it started to slip going into second, kinda like it is hitting neutral then 2nd.
With one of these slip in bands, are they also adjustable as they wear like an original? I don't want to do an "adjustment" and screw something up.
Thanks for any help.
Old Jan 4, 2024 | 03:57 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
72 inch pounds, I did 2 turns out on both.
Old Jan 4, 2024 | 04:03 PM
Upstate_Vet
Yes, thank you. My question is. The trans shop put a slip band in there two years ago. Is the slip band also adjustable like an OEM band is as it wears out?
Old Jan 4, 2024 | 04:36 PM
AtomicDog's Avatar
AtomicDog
Post
Yes. It adjusts the same way.
