Leaf Spring Bushing Replacement
Old Feb 9, 2024 | 01:57 PM
  #21
latkelarry's Avatar
latkelarry
Originally Posted by Keith_L
I typically order from Alcan Spring or if you have a local spring shop they'll bend 'em up for you.
You need to know spring width (should be 2.5" on a 1/2t), stock diameter (probably 14mm or 9/16?) and leg length which can be approximate. Also specify square or round bend. Since Dodge chose the stupid spring plate under the axle you should need square bend.
https://youtu.be/DWZmBlnmEZY?si=ROYG480joUw_yyRW
Don't order anything Husky Spring from RA. Total garbage. Note aftermarket will likely be longer and you can trim to length once snugged. Aftermarket also runs the threads much "higher" so you're less likely to run out of threads if you order a little long.
Thanks for the information; I measured my leaf springs and confirmed the measurements, 2 1/2" spring width, 9/16" diameter (roughly), and 7.75" overall length. I ordered a set of new ones from https://uboltstore.com/ per AtomicDog's recommendation. Thanks everyone for the assistance!
Old Feb 9, 2024 | 03:10 PM
  #22
AtomicDog's Avatar
AtomicDog
Lightbulb
You can always call those folks directly to ensure that you ordered the correct U-bolt for your needs. Be sure to order the nuts as well, as I believe they are ordered separately...
