Swapping a Dana 70 drum brakes to Dana 80 disks brake on a 2000
Installing one that is SRW , Didn’t buy one yet , looking at some right now. Gonna put a photo once I get one! They only made Disk brakes from 2001.5 to 2002.5 so a bit rare. And even more rare with a Dana 80 that has my ratio!
Yes there is! Found a few ones on marketplace, going to look at one tomorrow! But they are indeed hard to find
Make sure the rear you get came out of a 2nd gen truck. If not, the spring perches may not be in the proper location and new spring perches and grinding/welding may be in order.
My question still stands, ARE there any SRW dana 80s? They only came behind the diesel, with a manual trans...... Suppose you could possibly find one from a 2500..... but I don't think "rare" even begins to describe it.
The parts manual is your friend. Listed single wheel Dana 80 components (axles) back to '94, diesel or V-10.
From TorqueKing up in Billings: "Dodge used Dana 80 Rear Axles in Ram 2500 models equipped with Cummins Diesel or gas V10 engines and manual transmissions. The Dana 80 was also used on ALL Ram 3500 trucks regardless of engine or transmission."
They sell disc brake components for SRW/DRW Dana 80 axles, 2001-2002: https://torqueking.com/category/brakes-1994-2002-ram-dana-80/. https://torqueking.com/category/expl...-ram-dana-80r/
This page is especially useful, lists ( apparently) all possible combinations.
Poking around O'Reilly's site (which is where I've had problems before), they list a D80 wheel seal which does seem to be for drums as they also list 13x3.5" brakes (these are dims you'd only give for a drum) with 3" ID
However the "D70" seal has a 2-7/8" ID, which is what our disc'ed '02 uses. It definitely has a D80 chunk but the spindle is smaller.
Since the 70's and 80's are both full floaters, does what brakes it have on it even matter?
The rear hubs and the brake parts where not made by dana. These were all made by Chrysler so you need to look at the parts book to determine any differences.
Are you installing a disc brake Dana 80 with single rear wheels or dual rear wheels? What year truck did the disc brake rear come out of? Got a photo of it that you can share here?
