No blower truck shuts off with lights
Old Feb 13, 2024 | 09:04 PM
Dodgeguy123.'s Avatar
Dodgeguy123.
Default No blower truck shuts off with lights
Was driving home from work and I stopped to drop something off at a buddies house as I was getting out of the truck it shut off as did the blower I didn’t turn it off either I thought maybe the computer had no bus cause that’s happened before from a broken ground wire but it was all good I found out the engine control 2 wire was falling out I got that fixed and the truck running but as soon as I turned on the park lights the truck shuts off I pulled the fuse so I had headlights to get home but when I got home I put the fuse back and it still shut off the truck and the blower still doesn’t work but that is less important it could have just had the bolt fall out and it move towards the firewall and not be able to turn or the motor could be bad but I do need lights any help is much appreciated
Blake
Old Feb 13, 2024 | 11:20 PM
AtomicDog's Avatar
AtomicDog
You can download the factory service manual for your year truck via this link - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Check out the chapter on wiring diagrams, as it sounds like you have a short somewhere.
Old Feb 14, 2024 | 07:09 AM
Dodgeguy123.
sounds good thanks for the diagram I’ll look when I get a minute
