High idle
Old Feb 15, 2024 | 06:53 PM
KameronG11's Avatar
KameronG11
Default High idle
I've been having an idling issue with my 5.2. Its been idling high around 1250rpms at park and when it's in drive it idles at about 800. Sometimes it's constant and sometimes it'll surge. And other times it'll idle like it's supposed to. I've tried listening for vacuum leaks but I can't hear anything. Any ideas?
Old Feb 15, 2024 | 08:57 PM
What are you driving??
Old Feb 15, 2024 | 08:58 PM
KameronG11's Avatar
KameronG11
97 dodge ram 1500
Old Feb 15, 2024 | 08:59 PM
Pull the air filter housing off, crack the throttles wide open, and have a look down there. See any oil? If so, blown plenum gasket. See the stickied thread at the top of this forum, (end all, be all, plenum thread) for more information than you would ever want about this issue.
Old Feb 16, 2024 | 10:27 AM
KameronG11's Avatar
KameronG11
I replaced the plenum about a year and half, almost 2 years ago. But when I look down in there, there's not oil pooled up in there but there's light brown spots only in the very back. And the rest is pretty clean other than what the pcv valve spits in there
Old Feb 16, 2024 | 11:09 AM
What is manifold vacuum at idle?
Old Feb 17, 2024 | 09:42 AM
Moparite's Avatar
Moparite
It could be the pcv valve, They leak and cause the idle to go up.
