Runs smooth when cold but timing starts jumps as it starts warming
Old Feb 20, 2024 | 12:51 PM
Jamesbrwn's Avatar
Jamesbrwn
Originally Posted by Moparite
Did you fix the plenum issue? If it leaks it will affect timing. How are you seeing the timing? You can use a timing light and check the balancer. You can set the distributor like this on #1 CYLINDER TDC COMPRESSION STROKE to get the fuel sync. With worn parts use a scanner.
What was the plenum problem? It doesn’t have a vacuum leak as I tested it. And yes I am using a timing light to watch the timing
Old Feb 20, 2024 | 03:05 PM
AtomicDog's Avatar
AtomicDog
Here's documentation on the plenum problem - https://dodgeforum.com/forum/2nd-gen...um-thread.html
Get up under the hood, open the throttle body blades fully and look down into the plenum with a flashlight. If you see oil in the floor of the plenum, the plenum gasket is blown and needs to be replaced. This is a common issue on all 5.9 engines with a stock intake.
Old Feb 20, 2024 | 03:18 PM
Jamesbrwn's Avatar
Jamesbrwn
Oh no that seal has been replaced along with the throttle body gasket
Old Feb 20, 2024 | 03:25 PM
AtomicDog's Avatar
AtomicDog
OK. Did you recently change it and verify that no oil is in the plenum?
Old Feb 20, 2024 | 03:28 PM
Jamesbrwn's Avatar
Jamesbrwn
Yes it was changed when I rebuilt the motor and I completely cleaned it out. And after opening the throttle body I don’t see oil
