Transmission problems (HELP)
Old Mar 2, 2024 | 06:30 PM
Gerson's Avatar
Gerson
Default Transmission problems (HELP)
Okay so, a while back my truck had problems when applying the throttle, when I shifted it into drive it didn’t move or barely moved at all with throttle applied, until i forced the truck to move, it finally started to drive normally but with really delayed shifts. I got tired of it so I decided too calibrate the throttle position sensor, Adjusted the bands with the right torque specs (72INCH LBS) adjusted TV cable, installed new selanoids and added fresh oil, it appeared to fix the weakness of the truck when turned on, BUT now the truck won’t shift into 2nd gear and gets stuck in 1st🥲, I’m pretty sure I did everything correct but I’m out of ideas on what other problems it be, do you guys think my 47re is finally dead?
Old Mar 3, 2024 | 08:29 AM
Getting any codes?
