2 or 4 wheel ABS
Old Apr 12, 2024 | 04:14 PM
Vanilla.Mil5shake's Avatar
Vanilla.Mil5shake
Default 2 or 4 wheel ABS
Ok, so dumb question here but I need to replace my wheel bearings and they are asking if I have a 2 or 4 wheel abs system and I'm unsure.
2000 Dodge Ram 1500 5.9l
Is there a way I can check using the VIN?
Old Apr 12, 2024 | 04:44 PM
Yep. Run your vin Here. (case sensitive, all caps please.) It'll tell ya what ya got.
Old Apr 12, 2024 | 07:57 PM
Vanilla.Mil5shake
Couldn't find it on the list. I must be missing something 😕
Old Apr 12, 2024 | 09:53 PM
AtomicDog's Avatar
AtomicDog
All trucks of that era have at least rear wheel ABS via the tone ring and speed sensor in the center of the rear differential. If your truck has 4 wheel ABS, check the front wheels to see if you see any wiring going to wheel sensors on each front wheel. If so, you have 4 wheel ABS.
You can also read more here, but it's a bit convoluted - https://dodgeforum.com/forum/2nd-gen...-breaks-3.html
Old Apr 12, 2024 | 11:37 PM
Vanilla.Mil5shake
Thank you so much 😁
