ignition failure
Old Apr 21, 2024 | 03:55 PM
bdog's Avatar
bdog
Default ignition failure
i have a 99 ram 1500 5.9l that shuts off at least the engine shuts off at random times while driving. i have looked at the power bow inside and out the inside fuse panel and almost every other cause i can think of any help would be a miracle?///
Old Apr 21, 2024 | 06:27 PM
Will it start right back up? Or do you have to wait a bit before it will start again??
Moving this to Second Gen Ram section for ya. Welcome to DF!
Old Apr 21, 2024 | 09:26 PM
AtomicDog's Avatar
AtomicDog
Have you scanned the PCM with an OBD2 scanner at the time the shutdown happens? Does it show any stored or pending codes? Is your battery in good condition and fully charged?
Old Apr 22, 2024 | 09:13 AM
buster123's Avatar
buster123
it starts back up and the port for the reader does not function battery is new alt new distributor tuned rotor replaced ignition replaced ignition coil replaced
Old Apr 22, 2024 | 09:43 AM
Keith_L's Avatar
Keith_L
Then the FIRST thing to do is figure out why no power at OBD port.
AtomicDog's Avatar
AtomicDog
Question
When you say "new distributor tuned", does that mean someone set the fuel sync when the new distributor was installed?
