Rear Wheel Growl?
Old May 6, 2024 | 06:02 PM
GL-AZ's Avatar
GL-AZ
Default Rear Wheel Growl?
I'm not sure how best to describe this, but here goes.
I have a 2001 Ram 2500 2wd diesel that on hard tight left turns like in a parking lot I feel a strange growl (not really a noise) in the left rear wheel. This has been doing it for three years. I've had the rear end fluid changed and the rear end inspected, but they said it was fine. I first suspected a tire but have since replaced all four. It kinda feels like I'm going over a marbley road. Does not do it at any speeds forward or back. I generally know what a bad wheel bearing feels like as I've had to replace some on other vehicles. However I've never had one go on like this for so long and only in tight turns. BTW, front end has also been inspected and is good. Any thoughts other than tearing down the wheel and inspecting the bearings?
Old May 6, 2024 | 06:10 PM
Jack up the rear, spin it by hand, how does it feel? Wiggle it in various directions, is there any slop?
Inspecting really isn't that bad, if a bit stinky......
Old May 6, 2024 | 06:15 PM
GL-AZ's Avatar
GL-AZ
I'm going to jack it up and check it this evening. I'll let you know.
Old May 6, 2024 | 07:04 PM
ol' grouch's Avatar
ol' grouch
A Sur-grip rear will sometimes have a slight shudder. I don't hear mine growl but I do feel the shudder. I'm also deaf as a post. You might just need a friction mollifier in your rear end.
Old May 7, 2024 | 06:04 AM
Moparite's Avatar
Moparite
Assuming this is an open rear i would suspect an issue with the spider gears. They turn the fastest in turns. When the fluid was changed what did it look like?
Old May 7, 2024 | 12:09 PM
GL-AZ's Avatar
GL-AZ
The shop that changed the fluid and checked it out said everything looked good. They said they couldn't see a problem. The shop came highly recommended. Even tho, I'm looking to find another shop that specializes in rear ends.
