v8 manual swap
Old May 30, 2024 | 02:36 PM
merc225hp's Avatar
merc225hp
Okay did this swap years ago. Let's see neutral safety wires are already there you just have to plug in the switch part. I think this also applies for the reverse lights, just plug it in on the tranny. Codes oh ya you'll have 4 I belive whatever. I still use my auto pcm, mind you it's Mopar performance pcm. Okay ckps sensor yes it's different than the auto one. I can get some pictures later for you of certain important areas.
I still use my auto steering column and yes it still has the auto gear selector...just to mess with people.
Old Jun 5, 2024 | 11:54 AM
merc225hp's Avatar
merc225hp
This is at the firewall, for clutch pedal.
Thats the shaft going through the firewall. Kinda a bitch to deal with.
Old Jun 15, 2024 | 11:15 PM
SharpieDodge's Avatar
SharpieDodge
Step one complete I have my donor truck. 2000, 2500 4x4 v8 factory 5 speed. Even got one with same cab and bed length so hopefully I can just use it's driveshafts. As a little bonus it came with an ez dump, tow mirrors and an offroad bumper with winch and lights, and brand new full length side steps. Next 2 weekends are busy so hopefully gonna get it stripped after work through the week then start swapping my truck in July. Will update after work is underway.
Old Jun 16, 2024 | 09:48 AM
Ooooo, that's a nice score. What's wrong with the truck, that it is being parted out? If it is in driveable condition, I would be real tempted to fix it's issues, and keep it intact.
Old Jun 16, 2024 | 02:41 PM
SharpieDodge
It was a long time landscaping truck. The body is very solid, very very little rust but interior is pretty rough. It's got over 200k of city driving on the engine but the trans is less than a year old. The pcm is failing, needs cats, ball joints and steering components. My main reason is I have an 02 with 80k, a rock solid body/undercarriage and near mint interior minus the dash. However my auto leaves alot to be desired.
Old Jun 16, 2024 | 02:50 PM
Ah, ok. That makes good sense. You should be able to sell off the parts you don't need, and likely make back most of your investment. Around here, those axles can go for 3-600 bucks a whack. If its an NV241 case, (which it likely is) those are rare as hen's teeth. If it's the 241DHD, those make hen's teeth look downright common...
Old Jun 16, 2024 | 03:34 PM
SharpieDodge
unfortunately I won't have somewhere to store it long term to part out so it'll most likely end up scrapped unless someone comes and gets it.
Old Jun 16, 2024 | 03:40 PM
So advertise the major stuff you DON'T want, right away. Scrap, you might get a couple hundred for the whole truck. You can sell ONE of the axles for more than that. Maybe talk to a buddy that lives outside of town somewhere.
Old Jun 16, 2024 | 06:49 PM
SharpieDodge
know anyone around jersey that would be interested? I'm not from here so no buddies less than 12 hours away sadly
Old Jun 17, 2024 | 09:07 AM
I'm in Michigan, so, I don't know ANYONE in Jersey.
