Door speaker new wiring
Old May 31, 2024 | 05:00 PM
4stgs's Avatar
4stgs
Default Door speaker new wiring
I’m hoping someone knows how to run new wiring from the radio to the front door speakers in my 99 1500. It is a non Infinity system and I believe the wiring was damaged when the heater core was replaced. The current speakers are aftermarket and are fine. I just need to find out how you get around the Molex connector / terminal mounted in the door that blocks the pathway to running new wire easily into the doors. I’ve had the door panel off and can feel the connector, but that’s as much as I’ve torn apart.
Old May 31, 2024 | 07:17 PM
I would be more tempted to trace the existing wiring, find the break, and fix it......
