No brake lights, No blinkers, No wipers, cluster lights stuck on, running light on
Old Jun 2, 2024 | 03:11 PM
ThatRedRam's Avatar
ThatRedRam
Default No brake lights, No blinkers, No wipers, cluster lights stuck on, running light on
No brake lights, No blinkers, No wipers, cluster lights stuck on, running light stuck on in front and rear. I cant find anything thats not grounded. I unhooked the light switch still same issues. The wipers dont work, blinkers dont work, brake lights dont work, Taillights are stuck on, The amber/blinker lights in the front are stuck on, all stock headlights and taillights, i think i have the cluster tied into the radio power so thats why the cluster stays on which i am fine with.
Old Jun 2, 2024 | 03:13 PM
ThatRedRam's Avatar
ThatRedRam
Headlights and bright lights work properly.
Old Jun 2, 2024 | 03:45 PM
AtomicDog's Avatar
AtomicDog
Did all of this happen suddenly or is this a truck you ran across that you're trying to repair? Sounds like you may have multiple issues. If you haven't already, download the factory service manual for your year truck and check out the electrical diagrams via this link - https://dodgeforum.com/forum/2nd-gen...e-manuals.html
Old Jun 2, 2024 | 04:01 PM
ThatRedRam's Avatar
ThatRedRam
the truck is swapped to a 75 motor and 5 speed swapped and it has been a restoration project so i just got it back running and am now suddenly having all these issues
Old Jun 2, 2024 | 04:02 PM
ThatRedRam's Avatar
ThatRedRam
the entire original engine harness is no longer connected. I only have the harness for the accesories and headlights etc.
Old Jun 2, 2024 | 04:45 PM
ThatRedRam's Avatar
ThatRedRam
so if i pull my radio fuse out. my blinkers work. The running lights turn off in the front so the headlights all work properly with the radio fuse out. Still no brake lights tho. I must have the cluster and everything tied into the radio some how but any idea on the brake lights not coming on when hitting the pedal and the rear running lights staying on besides when the blinker is on.
Old Jun 2, 2024 | 04:56 PM
AtomicDog's Avatar
AtomicDog
What year & model is the truck? 2wd or 4wd?
Old Jun 2, 2024 | 05:26 PM
ThatRedRam's Avatar
ThatRedRam
1995 dodge ram 1500 4wd 5 speed 75 model 360. My problem changed entirely. So only issues im having now is rear running lights stay on and the brake lights dont work when i hit the pedal. When the blinkers are on the bulb stays lit but brightens up every blink. Also wipers dont work but thats an entire different issue.
Old Jun 2, 2024 | 06:14 PM
AtomicDog's Avatar
AtomicDog
Check the brake light switch for the brake light issue..
Old Jun 2, 2024 | 06:27 PM
ThatRedRam's Avatar
ThatRedRam
you were right. So now everything works except. No rear running lights when the headlights are on. and windshield wipers do absolutely nothing
