Loss of electrical power
Old Jun 2, 2024 | 04:20 PM
panda2gen's Avatar
panda2gen
Default Loss of electrical power
My truck ran great for 2 months after I put an external voltage regulator on, but recently it’s been having trouble starting. I’ll go to start it and the dash lights will turn off the cab lights shut off I have no power, if I go and wiggle the negative terminal I get power back and it turns on with no issue. Could it be a loose ground? I can’t figure it out
Old Jun 2, 2024 | 04:57 PM
AtomicDog's Avatar
AtomicDog
Sounds like a loose ground cable. Check both ends of the cable to ensure it's connected well.
Old Jun 2, 2024 | 06:16 PM
panda2gen's Avatar
panda2gen
Also if I hit bumps/potholes in the road going decently fast my Gen light will flicker on and my RPMs will shoot down but the truck immediately saves itself from dying
Old Jun 2, 2024 | 07:39 PM
AtomicDog's Avatar
AtomicDog
Sounds like a loose ground cable at the battery as you described earlier. Check both ends of the cable to ensure it's connected well.
