Looking for help with this 1998 3500 4x4 5 speed v-10
Old Jun 18, 2024 | 08:43 PM
Big 10 inch record's Avatar
Big 10 inch record
Alrighty 👍 I'll check all the fuel system tomorrow. I did think it was kind of low but didn't have time to check it today.
Old Jun 18, 2024 | 08:50 PM
dodgetruck2's Avatar
dodgetruck2
Hows the compression? Does it fire on either? That would be a quick test if its sparking correctly, not so much a great test for compression.
Old Jun 19, 2024 | 09:56 PM
Big 10 inch record
Didn't have much time to work on it today but I checked the lines and didn't find anything wrong. Bought a real fuel pressure tester and checked it, yup 39 psi. and it doesn't hold.
Fuel pump #3 I guess🤷‍♂️ bunch of chyna junk.
I guess tomorrows another day🤷‍♂️
Old Jun 22, 2024 | 05:02 PM
Big 10 inch record
Ok finally got the new fuel pump, couldn'tget the nut on but figuredid try the new pump anyway. I got 45 and 49 while cranking. It's holding while off for 20 minutes stays at 40. Wouldn't hold before.
I tried the starting fluid. Nothing, tried pumping the pedal and it will flood.
Still looks like it fires just enough to burn what's just on the electrodes.
I got a top don scanner. Pretty nice for 60.00.
No codes. Live data says cam and crank in sync, the temp sender is 19° Celsius🤷‍♂️. I tested everything with this thing (solenoids, injectors etc.)
Checked spark again, still sparking🤷‍♂️.
I still can't believe 3 fuel pumps and 4 crank sensors🤦‍♂️🤦‍♂️🤦‍♂️ bunch of junk.
So what am I missing🤷‍♂️
Old Jun 22, 2024 | 05:27 PM
Big 10 inch record
🤔🤔🤔timing chain jump 🤷‍♂️🤷‍♂️🤷‍♂️?
Old Jun 22, 2024 | 06:38 PM
If timing jumped, cam and crank would no longer be in sync. What did the PCM think engine temp was?
Old Jun 22, 2024 | 08:52 PM
Big 10 inch record
68° so it says
it was overcast and rainy
Old Jun 23, 2024 | 08:21 AM
I would kill for 68 degrees.... Been in the 90's for the last ten days here.....
Beg/borrow/rent some noid lights. See if the PCM is firing the injectors. Although, if starting fluid doesn't work, that rather implies a spark problem..... Test spark on at least four cylinders, 2 from each coil pack.
Old Jun 23, 2024 | 11:26 AM
Big 10 inch record
Actually it says we're at 78° and it's raining but so nice compared to the 98° we've been having.
So that top scan tool has a testing area where you can test everything.
I tested each injector (through the top scan tool each one can be tested) I can hear each one running.
I had tested some, ( too hard to get to on passenger side) not all the injectors with a test light.
As for the spark, I tested each coil and wire and the spark jumps the 3/4" gap in the tester.
To me it seems something is disabling whatever run circuit the computer has but I build mostly classic cars/trucks so what do i know?🤷‍♂️
I'll get a couple of noids and see if I can get in there, raining now so not today.
But would i really need a noid if a test light is the same?
Old Jun 23, 2024 | 12:02 PM
A test light will work just fine too. Noid lights are just a bit more convenient, if you have them. Since you already have the test light, just use that.
So you are indeed getting good spark.... but, it won't even fire on starting fluid? That seems mighty strange... What plugs do you have installed?
