2001 ram water leak
Old Jul 7, 2024 | 12:30 PM
jollygreen's Avatar
jollygreen
Default 2001 ram water leak
my 2001 ram has a water leak thats a mystery looks like the freeze plug is leaking.........is that possible
Old Jul 7, 2024 | 12:37 PM
aleekat's Avatar
aleekat
Coolant leak? Get a pressure tester loan a tool from most auto parts stores. Deposit to get it refunded when you return.
Old Jul 7, 2024 | 02:01 PM
AtomicDog's Avatar
AtomicDog
Post
Absolutely. The freeze plugs installed at the factory are steel. It's common for them to rust and leak over the years. If you see a freeze plug that's leaking, it can be replaced by removing the old freeze plug with a hammer and screwdriver and replacing it. Replacement freeze plugs can be purchased from any parts store. They are made of either steel or brass. The size of the freeze plugs in the engine block are 1-5/8". The freeze plugs in each end of the cylinder heads are 1-1/4".
