Electrical Issue!
Old Jul 21, 2024 | 09:08 AM
Joe Wood's Avatar
Joe Wood
OK so if it isn't the relays, what else should I be looking for, that would cause all those things I listed, to go out at the same time??
Old Jul 21, 2024 | 09:13 AM
Anything from as simple as a bad wheel speed sensor, or just a bad ground wire somewhere, to a failed computer. You really need to get codes read, and see what they are whinging about.
Old Jul 21, 2024 | 09:18 AM
Joe Wood's Avatar
Joe Wood
OK that's what I'll do tomorrow!
Old Jul 21, 2024 | 10:59 PM
Rebelwoc's Avatar
Rebelwoc
Originally Posted by Joe Wood
Two questions still -
are all the 5 prong in the relay box the same?
would one bad one cause these 3 warning lights to go on at the same time?
windows don't work and the Brake, Airbag, and AWS warning lights
They should all be the same. did you switch them out to see if it fixed your issue? I would've done that first but having spare 5 prong relays around can't hurt. Another thing you can do is turn the ignition on and off sometimes a relay will stick and turning the ignition off and on will sometimes unstick it. It's all hit and miss I just try to use the process of elimination. On the reverse side of the relay box cover there's a chart that identifies everything in the power center.Good luck.
