I little more power
#21
I was actually already looking into tuners. No point in coming it if I don't tune it to perform properly. And I'll look into those two intake manifolds. I found the Hugh's manifold but I didn't find anything else. Still surfing around to see my options. And thanks on the cam advice, why only 9.5 compression though? I've been told that number before but nobody gives a explanation for it. I'd imagine more compression has more efficient use of power?
#22
Higher compression will produce more power, but will require higher octane (premium) fuel, otherwise, you will experience knocking, pinging and likely engine damage. Here is a sample of what the M1 5.2/5.9 magnum fuel injection intake looks like - https://www.ebay.com/itm/134874194946
The Mopar M1 5.2/5.9 fuel injection intake was made in both 4 barrel and 2 barrel versions, in addition to EGR and non-EGR versions of both. In my humble opinion, either the EGR and non-EGR versions can be used without issue on either engine, as the EGR version can be blocked off. The intake is no longer made and is only available in the used market.
If you desire to tune the engine/PCM yourself, you can purchase HP Tuner software to tune the JTEC PCM in your truck and tune the PCM via a laptop.
#23
#24
