belts and things
Old Jan 10, 2006 | 01:46 AM
rogerdoger's Avatar
rogerdoger
Default belts and things
yet another question?!
was under the hood today while truck was running, and noticed a sound that kinda sounded like something was kicking in and out (on off)
looked around and saw that one of the pullies on the front of the engine would spin, then it would slowly come to a stop, then speed up again, while stoping and starting it would make a sound as if a compressor was turning on and off)
is this bad, or is it just maybe the a/c compressor (even tho it is not turned on in the cab)
thanks in advance
Old Jan 10, 2006 | 01:57 AM
REDKNOB's Avatar
REDKNOB
Default RE: belts and things
Yes it is the AC compressor and it is supposed to kick in and out even if it is not on in the cab.
Old Jan 10, 2006 | 02:00 AM
rogerdoger's Avatar
rogerdoger
perfect, thats what i thought
Old Jan 10, 2006 | 02:09 AM
shott8283's Avatar
shott8283
drives me nuts too... i pull the fuze during the winter,,but then i misplace the fuze during the winter then spend an hour tearin the truck apart lookin for it or go buy a new one.
Old Jan 10, 2006 | 02:19 AM
REDKNOB's Avatar
REDKNOB
There is a reason for this to happen and I even heard it once but damned if I can remember why. Maybe someone else can enlighten us.
Old Jan 10, 2006 | 02:44 AM
HuntinHanson's Avatar
HuntinHanson
The ac compressor runs during defrost. It has something to do with preventing the windows from fogging up during the process. Not sure exactly how it does it though.
Old Jan 10, 2006 | 03:15 AM
shott8283's Avatar
shott8283
weird... ive had it out for a few months now and my windshield and windows deforst just fine
Old Jan 10, 2006 | 05:00 AM
The Burning Rom's Avatar
The Burning Rom
Using it in the winter helps remove moisture from the air/windows inside the cab. That's why it turns on with the defroster.
It's also good to use it once and a while during the winter months. It helps keep the seals oiled and helps prevent loss of refridgerant.
