HELP! Manual 4wd broke and now truck won't move!
Old Sep 5, 2024 | 04:54 PM
Bo4's Avatar
Bo4
Default HELP! Manual 4wd broke and now truck won't move!
I think I am stuck between 4wd Low and 2wd and the truck is in a "neutral" state of drive train but not sure.
Truck details:
2001 Dodge Ram 1500 Laramie SLT 5.2L Engine
Here is the dilemma, I was shifting from 4wd Low to 2wd and the 4wd shifter got stuck. I tried freeing it by a bit of force then wiggling it, it then became all loose and I was not able to drive forward. Dash light shows 4wd is on. (sorry for not knowing the names. something with the transfer case)
I have discovered that the rod that attaches to the bar which connects to the shifter is not connected and the bar appears to be warped. Want a second opinion from someone who may know something other than basic look and see knowledge.
Old Sep 5, 2024 | 04:56 PM
Bo4's Avatar
Bo4
I cannot make the green rubber connector go back into the hole on the bar.
Old Sep 5, 2024 | 04:58 PM
Take the green feller off the post it is on, then stuff it into the hole on the lever by itself, then use a pair of pliers, or channel locks to squeeze it back in there.
Old Sep 5, 2024 | 05:59 PM
Bo4's Avatar
Bo4
The green feller won't come off without tearing it and I cannot seem to quite get it to line up. Any idea?
Old Sep 5, 2024 | 07:55 PM
I don't think you are going to get it thru the hole with it on there...... It's gotta come off. If you have alternate transportation, go to the dealer, and get a new one.... Or, while you are under the truck, (block the wheels...) and shift the transfer case into 2wd.... and take the truck.
Old Sep 5, 2024 | 07:59 PM
Bo4's Avatar
Bo4
Unhappy UPDATE!! Transfer Case is Stuck in 4wd Neutral...
So I have determined with my neighbor that the Transfer Case is stuck in 4wd Neutral causing it to not move. I was trying to shift too hard out of 4wd which caused the bar to break off. I am either going to have my cousin in laws mechanic look at it or it is gonna be sold as is... UNLESS someone can help with a much appreciated fix! Thanks in advance and thank you to HeyYou for the help.
Old Sep 5, 2024 | 08:00 PM
Bo4's Avatar
Bo4
How can I shift the transfer case to 2wd?? That is gonna be the fix I need. I can do without 4wd if needed.
Old Sep 5, 2024 | 08:23 PM
There is a lever on the t-case that the shifter is supposed to move. Block the front tires so the truck can't roll, jack up the rear, so both tires are off the ground. Figure out which way the lever on the t-case needs to move to get 2wd. I *think* you want the lever to rotate forward... That assumes that 2wd is the setting with the shift **** closest to the seat... Engine off, trans in park for this exercise.
Old Sep 7, 2024 | 11:00 AM
Keith_L's Avatar
Keith_L
Yep, you just need to move this lever. Your driveshaft won't be broken like this one
