Cheap suspension for a 98 ram 4wd
Old Sep 10, 2024 | 01:23 PM
thatgreen5.2's Avatar
thatgreen5.2
Default Cheap suspension for a 98 ram 4wd
I understand many people like to use a coil spacer around 2-3 inches to level their 2g. I've looked and seen 3.5-4 inch coil spacers, is that something I can do to lift the front end? also maybe maybe a bigger could spring. I've heard that I would need upgraded control arms which I understand but I was just curious if this is even possible because coil spacers are very cheap. Im used to my 02 Powerstroke with just lift blocks and springs, sorry to bother. Ill include the links for the parts:
-https://www.amazon.com/maXpeedingrods-1994-2013-2006-2010-Leveling-Spacers/dp/B097QT5DPG/ref=asc_df_B097QT5DPG/?tag=hyprod-20&linkCode=df0&hvadid=692875362841&hvpos=&hvnetw= g&hvrand=17178694221616579552&hvpone=&hvptwo=&hvqm t=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9006805&hv targid=pla-2281435179298&psc=1&mcid=4ff8fee4622d3b179e2a09a85 a009290&hvocijid=17178694221616579552-B097QT5DPG-&hvexpln=73
-https://www.4wheelparts.com/p/pro-comp-4-inch-lift-front-coil-spring-set-55302/_/R-DFCW-55302?ppcfon=1&gp=1&gclsrc=aw.ds&&ecmp=s:google_18 142422611___&utm_source=google&utm_medium=cpc&utm_ campaign=SC%20Shopping%20-%20Top%20&%20Performers%20-%20Performance%20Max&gad_source=1&gclid=CjwKCAjw3P-2BhAEEiwA3yPhwDhRKPWNS0tND9300I8p_tgnb89fKt5acbX7P s6DaP9T34TRFPjgbhoCx0cQAvD_BwE
Old Sep 10, 2024 | 01:27 PM
3" is all you can do without also addressing the control arms. Even that is going to be hard on various suspension/steering components.... Go any higher, and you need longer control arms, brackets for them, and steering modifications as well. (and likely track bar too...) If you want to do more than 3" of lift, just buy a GOOD lift kit, that has everything you need... Suspension is NOT something to cheap out on.
