Dragster v10
Old Nov 4, 2024 | 10:11 AM
V10dragster's Avatar
V10dragster
Default Dragster v10
Looking for the block dimensions bought a 18ft dragster and trying to fit the v10 in it any info would be very appreciated
Old Nov 4, 2024 | 02:56 PM
Which V-10? Truck, or Viper??
Old Nov 5, 2024 | 06:57 AM
Moparite's Avatar
Moparite
Not a lot out there for hopping up the truck V10. Better off with a big block.
Old Nov 5, 2024 | 01:25 PM
V10dragster
truck out of a 94 ram i know there isnt alot of parts for the truck really just wanted 400+ hp and what ever torque comes with upgrade its going in a car that weighs 1200lbs
Old Nov 5, 2024 | 01:40 PM
AtomicDog's Avatar
AtomicDog
Post
You could make those HP numbers easily with a pretty mild 5.9/360 engine and save a ton of weight over the V-10. In addition, parts availability for the V-10 is pretty much non-existent.
Old Nov 5, 2024 | 03:18 PM
This.
There is an EXTREMELY limited selection of cams for the 10.... and there are NO other intake manifolds available. You get the factory intake, or something custom made..... The stock intake is designed for use in a truck, it is not going to lend itself to use in a dragster, not to mention Redline is what? 4500 RPM???? Nope. You are trying to use the wrong motor.....
Old Nov 6, 2024 | 05:26 PM
adukart's Avatar
adukart
I would've started with a 96+ v10 so it'stune able. Then if its going in a drag car throw a turbo on it and build a sheet metal upper intake to direct the air straight down into the lower intake.
