Grinding shift
Old Nov 12, 2024 | 11:53 AM
levi b's Avatar
levi b
Default Grinding shift
I have 99 2500 5.9 Deisel with. NV4500. Recently started to notice a grind going to 3rd and 4th. At a stop takes 5-10 seconds before able to get into 1st 2nd and reverse at a stop. Never can down shift into 2nd while moving. Just replaced the master and slave assembly as I noticed a leak from the master. Still grinds. Got a valair hydraulic assembly and adjusted the rod all the way out. Same story. Before I begin driving the whole trans seems flawless and nothing difficult to get into. A while back added synchromesh and didn’t have problems driving when I did that. If I jack up the rear wheels I can drive through the gears without an Issue no grinding. Floating gears I get no grind whatsoever. Feels to me like the clutch isn’t fully working properly? Help would be appreciated!
Old Nov 12, 2024 | 05:49 PM
How many miles on the clutch? It does sound like it isn't releasing completely.... but, I would think what you have done with the hydraulics *should* eliminate that possibility.... Unless the fork itself is bending....
Old Nov 12, 2024 | 10:11 PM
levi b's Avatar
levi b
No clue on the mileage on the clutch as I bought it from a guy who barely used it and put no miles on it. Truck has 220,000 miles on it. In addition to what I said earlier if I double clutch I seem to have no issue with grinding at all even if I shift very quickly while double clutching. I also can shift into 5 quicky with no grind at all and down shifting from 5-4 is smooth as butter.
Old Nov 13, 2024 | 08:17 AM
Worn sychros? Though, first gear isn't synchronized..... neither is reverse.
