Tune?
Looking to put a 408 stroker kit with short tube headers and 1.7 rockers inside my engine. Stock cam, stock heads, and stock intake and injection system. Will I need to tube the truck for it to be safe to drive? I'm looking for maximum fuel economy with this setup so would the old tune work? And yes I know I'm not looking for better fuel economy than before I just want a little more get up and go without diving my fuel economy into the single digits. I currently get around 16mpg if I maintain 60-65mph
"better fuel economy" and "408" don't really go together.
If you are gentle you might get real lucky, and stay about the same, more likely though, you'll drop a couple points. For it to run properly, you WILL need a tune. How easy that is depends on what year your truck is. 96 or new, you can get a custom tune, and reflash the PCM, 95 and older though, that won't work...... as they are not flash programmable. Your options are pretty limited there...
