Horn Problem and K&N Cold Air Intake
Old Jan 11, 2006 | 03:31 AM
mattyge's Avatar
mattyge
Default Horn Problem and K&N Cold Air Intake
Hey everybody,
This one is a two parter, first my horn don't work! When i bought it they did but then they started going. To get them to work you would have to press them like 5 times and then maybe they worked, now they don't work at all. The horns are still good and the fuse and all the wiring so i have concluded that it's the horn buttons on the steering wheel. Problem is they're sealed and I don't want to fool around too much and set off the air bag. Any suggestions?
Secondly I wanted to know if it's worth getting one of those K&N Cold Air Intake systems that replaces the old stock airbox etc. and how much they would cost because on they're site they don't tell you how much they are.
Thanks for your help,
1995 Dodge Ram 1500
Club Cab, Long Bed
2wd, 5.2L (318) V8
Old Jan 11, 2006 | 10:16 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default RE: Horn Problem and K&N Cold Air Intake
Read this about K&N. http://www.duramax-diesel.com/spicer/index.htm After you finish reading you probably won't want the K&N any more, I know I didn't.
Old Jan 11, 2006 | 11:44 AM
Silver_Dodge's Avatar
Silver_Dodge
I have the K&N FIPK, and really like it. I think it is a very good mod. It is one of the best designed cold air intakes. If the filter study that Teacher posted worries you, you could always put some other brand cone filter on it. I paid about $220 for mine new off eBay.
Old Jan 11, 2006 | 04:29 PM
mattyge's Avatar
mattyge
Ok I think I'll look for one on ebay thanks for your imputs, now any ideas on my horn?
Old Jan 12, 2006 | 02:34 AM
mattyge's Avatar
mattyge
hey again,
I was looking on ebay and there are 2 different types of k&n intake systems and i was wondering if you could tell me the difference between them besides the price
K&N #1
and
K&N #2
also i would just buy the cone filter and make my own intake but i don't think i can make that funny piece that goes ontop of the throttle body.
Thanks again
Old Jan 12, 2006 | 10:14 AM
Off_Road_Teacher
If you want to make your own, you could get a set up similar to the first ebay link you posted (there are some on there much cheaper, I got the same thing for $40) and just use the air hat and filter. Then make your own pipe going from the hat to the filter. That is what I did and I think it turned out fine.
Old Jan 12, 2006 | 01:22 PM
shott8283's Avatar
shott8283
#2 is where you make your beans and tomatoes at... that has the heat sheild and the weather stripping... sooo sexy
Old Jan 12, 2006 | 03:02 PM
ebxgsxr's Avatar
ebxgsxr
i've been told that there could be a couple problems with the horn. im having the same problem and i've tested the horns and checked the fuses and all. seems like my problem is in the pad/clockspring itself. i havent taken apart my horn pad to check though.
