front suspension
Old Dec 20, 2024 | 02:53 PM
Whop's Avatar
Whop
Default front suspension
Replaced entire front end and now rides like a straight axle front end with no springs. Everything torqued to specs. Hardly any travel even though it did seem to be alright during assy. Suggestions?? To get on right page, 1997 Dodge Ram 1500 2wd, 318 or 5.2 which ever you like.
Old Dec 20, 2024 | 03:12 PM
Did you change the springs? What was the donor axle from?
Old Dec 20, 2024 | 05:19 PM
Whop's Avatar
Whop
Did not change coil springs, not sure what you mean by axle, it is 2 wheel drive
Old Dec 20, 2024 | 05:21 PM
Ah..... Ok, that changes things.
Was the suspension just hanging when you torqued things down? If so, than that is likely a significant contributor to your ride issues. You should have the truck sitting on the wheels, before you torque things like control arms, and such.
Old Dec 20, 2024 | 05:57 PM
Whop's Avatar
Whop
Actually, half was torqued while in air, upper and lower control arms. Shock absorbers and stabilizer bar done after being let down. Sooooo, loosen and retorque while on tires is ok?
Old Dec 20, 2024 | 08:33 PM
Should be fine. I would take it in for an alignment as well.
