Need help asap
Old Jan 8, 2025 | 05:17 PM
Ramtatmike311's Avatar
Ramtatmike311
Default Need help asap
I've got a 2001 59 2500 Magnum four-wheel drive went out in the snow the other day had to get the kids food got home just fine no issues go to start truck next morning I've got a coolant leak coming out the back of the motor money is extremely tight right now and I'm wondering what it possibly could be at the same time I noticed I have absolutely no breaks these two shouldn't be connected at all could someone please give me some advice tips help something
Old Jan 8, 2025 | 06:19 PM
Moparite's Avatar
Moparite
The leak is probably a freeze plug, Either behind the motor or back of the heads. Did you check to see if you have brake fluid in the reservoir?
Old Jan 8, 2025 | 07:47 PM
Yeah, two separate problems, neither of which is going to be inexpensive to fix...... unless you do it yourself.... Not something I would want to be doing outside in the cold though.
