Code p1391
Old Jan 16, 2025 | 07:42 PM
Asherpitch's Avatar
Asherpitch
Default Code p1391
I just bought this 5.9 magnum v8 a week ago and it’s got a check engine light. I just took my scanner to it and it gave me this code p1391. It’s also misfiring in cylinder 1. What’s going on I can’t seem to find anything online. My dad is pretty sure it’s a vacuum leak but I don’t know.
would you recommend changing out the crankshaft sensor? And I’ve been trying to research the location of the camshaft sensor and I can’t find anything could I get some insight to where I’m supposed to look
Old Jan 16, 2025 | 07:56 PM
Moparite's Avatar
Moparite
P1391 Intermittent Loss of CMP or CKP
Loss of crank or cam sensor. Crank sensors go more frequently than the cam sensors.
Old Jan 17, 2025 | 04:32 PM
Asherpitch's Avatar
Asherpitch
Default Dodge problems
I just installed a new crank sensor and it’s still having issues. Misfiring in cylinder 1 too
Old Jan 17, 2025 | 04:39 PM
What brand crank sensor? These trucks really don't like the aftermarket sensors......
Old Jan 17, 2025 | 05:14 PM
Asherpitch's Avatar
Asherpitch
Default Sensor
just one I picked up from my local auto parts store I can’t exactly remember the brand
Old Jan 17, 2025 | 05:39 PM
Probably duralast. But, if you changed the sensor, and are still having the same issue, pretty safe bet that its not the sensor......
Old Jan 18, 2025 | 03:49 AM
Moparite's Avatar
Moparite
Could be the cam sensor, Code is for both. If you had a high end scanner you could see on the scope witch one has the issue. Have you checked the cap/rotor, plugs and wires. Since you just got it you don't know the previous owner did.
Old Jan 18, 2025 | 09:26 AM
Teamvaught48's Avatar
Teamvaught48
Default Asherpitch
I thought p1391 code was a 02 sensor problem ?
Old Jan 18, 2025 | 09:28 AM
Nope. Intermittent cam/crank sensor.
Old Jan 19, 2025 | 11:43 AM
Moparite's Avatar
Moparite
Maybe somebody should make up a (updated)list of the PO codes and post it in the sticky's. I searched and see we have a diesel thread with them and these below but the 1391 is not there along with others(did i miss any?). Threads are closed so you can't update any missing codes. I have word document that has most of them but it's not helping any of the users here.
https://dodgeforum.com/forum/general-tech/15042-service-engine-codes-for-obd-ii-engines.html
https://dodgeforum.com/forum/general...d-engines.html
https://dodgeforum.com/forum/1st-gen...d-1-codes.html
