99 Dodge shift out of first or second I知 not sure which one it is cause no matter wh
Old Jan 29, 2025 | 01:09 AM
Hm2(FMF)Barnes's Avatar
Hm2(FMF)Barnes
Default 99 Dodge shift out of first or second I知 not sure which one it is cause no matter wh
Can someone knowledgeable please help it痴 a fresh rebuild and transmission. I知 pulling my hair out.
Old Jan 29, 2025 | 01:13 AM
dodgetruck2's Avatar
dodgetruck2
a little more information if you could, you're question is cut off in the title, you need to type the message in the big box. What was done to the truck, did you do it yourself, fluid level correct? electrical connected. Throttle kick down adjusted?
Old Jan 29, 2025 | 11:09 AM
Hm2(FMF)Barnes
My apologies, I rebuilt the trans myself it痴 got adequate fluid that痴 not old or burnt, it downstairs change whether it痴 plugged in or unplugged the shift solenoid seemed to work properly on bench test. I thinks it痴 in limp mode but I don稚 have enough knowledge as to exactly what limp mode is.
Old Jan 29, 2025 | 11:27 AM
Limp mode means it sees a problem, (which should set a code...) so it limits a lot of the trans function.... and what you do get, doesn't work that great.
Old Jan 29, 2025 | 06:21 PM
Moparite's Avatar
Moparite
Did you set the TV cable?
