1999 2WD Negative Camber after replacing Ball Joints
Old Mar 31, 2025 | 10:05 AM
bwannabeast85's Avatar
bwannabeast85
Default 1999 2WD Negative Camber after replacing Ball Joints
So I replaced my upper and lower ball joints, sway bar end links, and front tie rods on my 1999 Dodge Ram 1500 2WD with 209K. The truck didn't have any camber issues before the components where replaced, now wheels sit bow legged /-------\. I measured the tie rods and matched to the original. What's the best way to adjust?
Old Mar 31, 2025 | 10:59 AM
Tie rods control toe, control arms control camber.... Which one is the problem?
Old Mar 31, 2025 | 11:02 AM
AtomicDog's Avatar
AtomicDog
Lastly, what's the condition of the bushings in your control arms?
Old Mar 31, 2025 | 11:20 AM
bwannabeast85
It's Camber, the top of the wheel leans into the truck.
Old Mar 31, 2025 | 11:27 AM
bwannabeast85
I feel like an idiot but I think I figured it out, the upper control is loose it slides back and fourth if pulled on hard enough. Going to tighten them up and see if that helps.
Old Mar 31, 2025 | 12:57 PM
Take it in for an alignment.
