Brake fluid leak
Old Apr 9, 2025 | 10:40 AM
Chaserjay88's Avatar
Chaserjay88
Default Brake fluid leak
I was wonder if anyone could help me with my brake fluid leak its coming from or around the rear brake drum the bake of my tire is covered and my drum also looks covered and part of under of my axle is covered it brake fluid and I’m going to take it apart anyways but was wondering if anyone else had this problem and could help me
Old Apr 9, 2025 | 11:42 AM
Blown wheel cylinder most likely. Or a broke bleeder valve, cracked brake line, etc. You need to remove the wheel, and drum and inspect.
Old Apr 10, 2025 | 08:41 AM
Chaserjay88
I looked further without taking it apart it looks like its coming out of the top line on the back of the brake and it seems to have gotten worse
Old Apr 10, 2025 | 08:51 AM
You should fix that ASAP before you lose your brakes completely while driving.
Old Apr 10, 2025 | 08:52 AM
Chaserjay88
Haven’t been driving it was just wondering if you know what it would be
Old Apr 10, 2025 | 09:09 AM
HeikIlm's Avatar
HeikIlm
Well, it's rather hard to diagnose your truck over the internet. You'll just need yo get your hands dirty and find where the leak is coming from.
Old Apr 10, 2025 | 09:13 AM
Chaserjay88
Im pretty sure i found out what it is its either the cylinder or the line that goes into it cause its leaking right at the fitting but first ima try to adjust the bleeder just to se if that fixes it
Old Apr 10, 2025 | 09:36 AM
HeikIlm's Avatar
HeikIlm
Brakleen and compressed air, pinpoints the leak instantly.
Old Apr 10, 2025 | 09:37 AM
The bleeder is completely separate from the cylinder or the line. Bleeders are not "adjustable". They are either open or closed. If that's what's leaking, then yes, you can try tightening it. But that has nothing to do with a leak at the brake line or wheel cylinder. Clean everything off, have someone press the brake while you are watching everything.
Old Apr 10, 2025 | 09:54 PM
AtomicDog's Avatar
AtomicDog
Is that the original metal brake line on your truck? The newest 2nd gen truck is over 20+ years old. Those metal brake lines get rusty and/or brittle with age and may have rusted out or gotten twisted when replacing a wheel cylinder. Please check those metal brake lines closely and replace them as needed.
