2000 5.9 cummins losing prime
Old Apr 10, 2025 | 12:13 AM
tbug45's Avatar
tbug45
Default 2000 5.9 cummins losing prime
starting about 2 weeks ago my 5.9 cummins seems to lose prime everytime i go to start the truck, i have a fuel pressure gauge and it reads 0 when i put the key in accessory mode, while the fass 165 is running i go and crack the filter open till it bleeds out fuel then i have the 17 pounds of pressure and it doesnt dip at all, but when its primed it sounds like its sucking air, im assuming its a return line somewhere but not too sure, truck runs and drives without skipping a beat when it has all the pressure it needs, but its literally every time i turn it off i have to re-prime the system, was looking for leaks and cant seem to find any at all, could it be a bad lift pump? fuel filters? ive read it can be the o-rings for the cross over tubes so im gonna start with changing those but no leaks anywhere is really confusing me, any help is appreciated.
Old Apr 10, 2025 | 08:19 AM
Where is the check valve to hold pressure on the system when the pump isn't running?
Old Apr 10, 2025 | 12:10 PM
tbug45's Avatar
tbug45
i have no idea
Old Apr 10, 2025 | 05:21 PM
Originally Posted by tbug45
i have no idea
Neither do I.
Old Apr 10, 2025 | 05:22 PM
tbug45's Avatar
tbug45
Neither do I.
i imagine its on the fass ill look into it this weekend
Old Apr 10, 2025 | 10:57 PM
dodgetruck2's Avatar
dodgetruck2
If the fass is drawing air, you have an issue with a filter seal ring, or water drain, possibly a suction hose.
How is the FASS drawing fuel, sump, draw straw, factory module connection? Does it act worse on an empty tank vs full tank?
Old Apr 11, 2025 | 12:41 AM
tbug45's Avatar
tbug45
does not matter how full tank is, the old owner hooked it up to the factory module, at least i beleive so, i ordered a sump because i have the 1/4 tank issue aswell, but i have noticed it doesnt lose prime when the face of the truck is facing up hill, mainly because the only place i park uphill is my driveway and its always primed when i go to start it
